1 - 20 of 25 Posts
hey all, i fitted a momo steerting wheel a while ago and didn't bother wiring up the horn, now that its mot time i have a problem, i was wondering if anyone could help wiring it up, i've thorwn ma old wheel away long time ago :( and dont really know what type of wiring to buy and what to connect :(
on my mates corsa b, the horn was just a button in the wheel, and when you push it, it simply connects two contacts together, the circuit is completed, and the horn sounds.
was this like the wheel you had?
Go to a scrappy and put a standard wheel back on for now:)
hehe, ye sounds a good idea,
well there are two contacts on the wheel its self, but theres only 1 wire thats leading through to the wheel (brown and white) which has a long brass connector on the end that moves back and forward but doenst contact anythin....hmm im getting confused now...
what did you do wth the two wires that were going into the steering wheel? does you momo wheel have a button any where on it?
or do what i did :) connnect a wire to the wire behind the contact on the steering column, and fit a horn button down near your fog switch :) just make sure you tell the MOT guy its there and your fine :p
dont have any wires that where on the orgional wheel anymore, the brown and white one is on the car and is the only wire leading to the wheel, there are two connectors on the horn button in the wheel
i do like the idea of fitting a new button on the dash for it, any special kind of wire that i need for that?
awrite cool, ill nip out and by some connectors and wire and see what i can do in the mean time, thanx
Just phoned Lee and he said
Take the steering wheel off so youcan see into the boss, connect the horn wire to 1 off the contacts on the momo horn and the other contact on the horn to earth (any metal part of steering wheel)
brown is usally earth if that helps. maybe you just earth that wire and the horn sounds? although its very bad practice to have a a switch in the earth, its usually done through al ive...
With my momo wheel i just used a ring terminal crimp for the earth wire and put one of the steering wheel screws into the boss kit when I fitted it. it works fine for an earth and is in secure.
Let us know how you get on then mate hope all goes well!
awesome idea, why didnt i think of that? :p
1 - 20 of 25 Posts
