1 - 8 of 8 Posts
Heyaz
We've removed the centre consol from my corsa B, unclipped everything... but how do we get the actual heater control dials things off so i can replaced the LED's behind them??
Do they just lever off or is it something more complicated?
use a small screwdriver at the bottom of the dial (in line with the raised bit) and gently work it behind the dial while you prise it off. this pulls the release tab away from it's little lock, so hopefully it won't snap like it might if you pull it straight off.
look at where ive put the red lines, on the one of the sides of the knobs theres a wee square cut out, what you can do is push a wee allen key of thin metal stick thingy into the cut out and pull the knob off
d
Thanks guys.. got em off in the end.
one of the lil bits of plastic was all mushed so it cldn't be pushed in to pull the switch out... bit of grinding and it worked Lol
1 - 8 of 8 Posts
