It's a case of unbolting the bonnet basically. But then you've gotta undo your washer jets & then refit them - that's the pain! It's difficult to thread the lines back through.
4x10mm bolts and pull the washer jet pipe off the pump on the washer bottle, then unclips the jets from the bonnet and refit them to the new bonnet, then its just a case of lining it all up which all you do it tighten them up but not all the way then close the bonnet and with the little movement you have push it in o place and open the bonnet again and tighten the bolts right up and that the job done
davie
may take a bit of wobbling on the bolts to line it up, easiest thing to do is offer up the new bonnet and just nip the nuts up so you can jiggle it till it lines up
