jus check mine it does only have 3 bolts.duno if its the same on the newer 5 doors i very much dout they changed it.mines a 5 door n-reg 1996.took these quick with my phone let me no it you want better 1's.
pic 1 is the bottom right hand corner clearly visable.
pic 2 is the left hand corner you can see it if you move the wirers out the way.
pic 3 is the to right hand corner tucked behind the body work a right barstard to remove.
hope this helps you with your tutorial lee.
