In this following tutorial you will learn or revise how to refurb your wheels
Simple guide, easy to do but worth a read.
Tools.
Colour paint, primer, lacquer, masking tape, wet & dry sandpaper (600/1200).
Step 1 :
locate the wheel/s you wish to Renovate, (normally found on each corner.) lol
Step 2 :
Wash with a little soapy water and Remove dust, dirt, polish, etc. from the
wheel area prior to beginning masking, preferably by using compressed air to
blow dust and water away,
Time spent at this stage will remove the risk of the tape peeling back during
the painting process. Tape all edges of
wheels, using paper to cover larger areas.
Apply tape to the exact edge with no overlap in either direction.
If in doubt, practice a little or get someone with better eyesight to do it!
(not my picture somehow mine was lost.)
Step 3 :
Start to key all areas that will be painted. Where surface rust is evident,
Sand gently and fill with a little easy sanding filler, untill totall smooth and
flat.
Step 3 :
Holding the spray can approximately 25cm away from the surface to be
painted, apply a number of coats of primer at 15-minute intervals until the
area is evenly covered. Go an inch over the original layer of paint to help it
blend in (to create an even softer edge, peel the masking tape back from the
surface slightly). When spraying, use a smooth movement from side to side.
It is best to apply several light layers of paint, as applying too much paint in
one go can create sags and runs.
Step 4 :
Allow for the primer to dry thoroughly, then rub down with 1200grit wet and
dry paper until smooth. Clean the area with warm, soapy water, rinse, then
dry fully.
Step 5 :
To start painting, shake the can vigorously for two minutes to ensure the
paint is thoroughly mixed. Apply a number of coats at 15-minute intervals,
shaking the can between each one.
If you're using a metallic colour, allow the paintwork 24 hours to dry then rub
it down with 1200 grit wet and dry paper. It should lose its gloss appearance
and take on a dull, matt finish. Clean with warm, soapy water, rinse and dry
Step 6 :
Now apply two coats of lacquer, separated by a gap of 15-minutes. If
the finish looks patchy/runs orange peel, apply another coat or wait until the
surface is completely dry before rubbing it down and starting the lacquering
process again.
Result.....................
Cost
1 x primer £4.99
1 x paint £4.99
1 x lacquer £4.99
Wet & dry £2
so about £17-18 give or take..
whats next....
if i've missed anything let me know, :thumbs_up:
Tools.
Step 1 :
Step 2 :
Step 3 :
flat.
Step 3 :
Step 4 :
dry fully.
Step 5 :
Step 6 :
process again.
Cost
1 x primer £4.99
1 x paint £4.99
1 x lacquer £4.99
Wet & dry £2
whats next....
