1 - 7 of 7 Posts
Hi Guys
This is my first post here, I need to replace the camshaft on my sister's 2006 corsa 1.4 8 valve Fuel Injected engine the oil feed holes on two of the lobe's blocked and the cam is a gonner probably the cam followers too.
I am handy with tools and engines so be technical if you like..
What i need to know is: can the camshaft be removed without taking the cylinder head off?
Does the cambox come off without loosening the cylinder head?
Any help much appreciated, i need to fix this tonight or at latest tomorrow.
:thumbs_up:
Hey there
My cam belt snapped last year and had to replace a few valves,
Its a day job if you're not to clued up on things,
On mine, I had to remove the head, If i remember correctly the head bolts went through the cam box,
I left the intake on the head and just removed the piping and so on.
Hey Marbro Fancy meeting you here!!
I thought as much for the head bolts going trough the cam box.
If at all possible i dont want to disturb the head, my valves are still fine, belt didnt break but the engine started running uneven, so i had a look inside and found the cam in bad condition.
yeah theres about 5 of us on here. cause the SA guys just dont care,
well you could just leave the head on, but the bolts need to be out
where you based?
Okay so where 6 now ;) Same on the Renault's SA guys dont care ....
I'm about 100km South of JHB, Vaal triangle. (Berny's friend although she forgot about me)
I've been reading a bit on the net, apparently there is a tool to remove the cam followers then you can just pull the cam out, my concern is whether the space will be enough with the air filter box out.
The tool seems to depress the hydraulic lifters then the followers can be removed.
Plan A is getting the cam out in position
Plan B Removing the cambox without disturbing the head
Plan C (last resort) removing the head
Its a second gen Corsa bakkie BTW
Uploaded with ImageShack.us
So if any one wants to venture into this:
The cam can be removed without removing the cambox or head with the help of the tool above, on each cylinder remove the inlet rockers first and then the exhaust vale rockers, unscrew the fuse box (gearbox side) unclip the water bottle lift the lot up and pull out the cam.
I am unfortunately still waiting for my new cam to arrive at the local spares shop, so i will still have to see if reassembly is just as easy
Hi guys from SA. I have a Corsa 1.4i that has broken the rocker arm of the second piston. I went and bought a set of 8. Somewhere I read that if one rocker brakes then others are likely to follow. I also read of a guy with a 16v 1.6 who found all 16 inlet rockers broken... I have a fair amount of mechanical understanding and from what I can see it looks like that camshaft could just slide out but I do understand the need for a tool to compress the valve spring with. Any idea where to find said tool?
1 - 7 of 7 Posts
