1 - 8 of 8 Posts
Right my corsa B's batterys flat again. If I dont drive if it for one day and the weather is bad its as flat as a flute. I even started it yeterday too.
I don't know what the problem is but the easiest thing would be that the batterys nakerd.
Somethings draining it and the things that we thought could contribute are the additional alarm that was added or my new head unit. But its flat as a flute today and I didn't put the alarm on. Ive not put my HU on for days neither. But I haven't been turning the HU off, i just leave it on and then take the keys out and remove the face
please help
put your tongue between the two terminals and if it electricutes u then u know its not dead :)
on second thoughts go to your local car shop, they should have a tester and itll tell if your batteries just flat or if its totally ****ed, i nwich case itll need replacing.
use a multi meter, also check the earths, and check the alternator belt isnt loose and check interior lights arent staying on when the boot is shut etc.
your battery isnt keeping its voltage. so either your alternator is fooked or the battery is shagged. battery being the cheaper cause. you see at my work i can test the battery and alternator for you, and im sure alot of car places will, but im not sure?
anyone know if halfords or anywhere do this service?
cold weather can tell if a battery is fooked the cold reacts with something, and lets face it its not warm over night. could be that !
Definately has the symptoms of the battery not holding it's charge.
Yes i work at halfords , if you go to halfords they do a test on your battery and its free ;) we also do a check on your fuse's , blubs etc .
All that is free? Hmm...maybe I can diagnose what's wrong with my courtesy lights (glovebox and interior).
1 - 8 of 8 Posts
