A lot of people ask how what is causing a noise in their engine bay, and that is a big field as engines can make lots of different noises. So I might need to add to this bit by bit, but I'll begin with the most important bit of diagnostic kit in your toolbox - the stethoscope
Available from (as I've pinched their picture) http://www.justoffbase.co.uk/Technicians-Stethoscope-Sealey-VS871
Using a stethoscope allows you to accurately pinpoint the source of noises safely and easily and they are not expensive. This will be one tool you'll use time and time again if you work on cars regularly.
So why use a stethoscope?
Firstly you are hearing the noise with both ears, and since both ears are blocked with the earpieces ambient noises are cut down.
Secondly the tips of the stethoscope allow you to listen to noises without getting your hear, hair or clothing near moving parts. Obviously care is needed, don't go sticking your fingers into a moving belt.
Thirdly, this particular version offers a metal probe which safely reaches awkward places, and a plastic trumpet which is helpful for tracking down air leaks. The trumpet will amplify localized noises which your ears cannot pick up.
Different versions at varying prices are available http://www.justoffbase.co.uk/Tool-Shop/Mechanics-Stethoscopes but the one above does everything I usually need.
Just one example of how it sounds - in this case on fuel injectors
) has pretty awful sound quality but the first part of it shows the stethoscope in use, and also the alternative - which is a big screwdriver or metal bar. The screwdriver works, but it is less accurate and obviously less safe. It also cannot be used easily on hard to reach places. But for listening to valve gear it works pretty well.
