i know this was posted a while ago but yes it will as it uses the double din standard, you will need the double din facia to fit it with link herehttp://www.ebay.co.uk/itm/Vauxhall-Corsa-C-Tigra-Vectra-Double-Din-Stereo-Fascia-Fitting-Kit-Adaptor-/251153745373?hash=item3a79ee05dd:g:pJgAAOSwKtlWn-SE
you will also need to remove the oem radio cage, once the radio is removed there might be a screw holding it in iirc, pop out the connectors(they are clipped in) take out the old cage, push in the new facia, then iits just the normal aftermarket radio installation
