Hi All, My injector wire from ignition live burnt out as it was too thin. I've re wired it all with 17A rated Wire however I need a new place to get a good quality ignition Live feed from.
Which would be the best place to splice into? Direct from barrel, Fuse box or any thick ign+ wire?
Also what Amp rating should I place with the in-line fuse for safety measures in case it doesn't blow out again :L
For c20xe corsa
For c20xe corsa
