I have had a sudden bout of trouble starting my corsa diesel merit P reg, after no problems. One day I turn key and it kicks right up, another it just clicks. mechanic says I need a new starter (Japanese - Isuzu engine?) but it seems because it seems fine when its fine, that it is just a loose connnect somewhere. anybody got any ideas? gratefully received! thank you!
Your mechanic has seen the car, we haven't. It could be a bad contact somewhere externally, or an intermittent internal fault.
Presumably he's checked it's not down to the battery, in which case the only thing you can do is to make sure there's no dodgy connections anywhere, then replace the starter.
