Hi,
I have a Corsa C 1.2 16v SXi Twinport (55 reg) and have the occasional problem whereby if I start the engine when it's warm it can struggle to start and then when I first move away it can be jumpy. It doesn't last for very long (only a few seconds) but I would like to get the problem sorted and wondered if anyone knew what it may be?
I have done some research online and I don't know if its the MAF, CTS, Lambda sensor, EGR or Crank shaft.....
There was a service done by the dealership (not main dealer) just before I purchased it at the end of jan last year, but I'm not sure how indepth it was. I've done about 10-12k in it since then.
So I replaced the air and fuel filters but made no difference.
I did the pedal test but no codes seemed to show up.
Could it be the coolant temp sensor? I may replace that if so as it's cheap and easy. However, I have also read about people changing the crank shaft sensor but wouldn't that make it cut out more rather than just struggle to start?
Does a failing CTS not always produce a fault code?
Thanks for any help.
