1 - 12 of 12 Posts
i finally got round to putting on my alloys yesterday, i had to use a spacer kit, because the wheel was catching on the hub. however because i used the spacer kit, the wheel now stick out from the wheel arch by about 4cm, also the wheel is catching on the wheel arch when i turn so i will have to sand it down or something. could some one please tell if this is illegal to have the wheel pretruding past the wheel arch?. thanks.
Its an MOT failure, what spacers do u have on it? it cant look good if its sticking out the arches by 4cm, you offset is out by miles. you got a pic?
Yup its illegal, the wheels are not allowed to be wider than the arches
technically they are aloud too...
BUT, your treat has to be covered by your arch, hence if you see euro motor's with really wide wheel's, they have streched tyre's, so keep the tread under the arch :thumbs_up:
lol @ Ash-uk.
i made up a pipe for my tractor lawnmower one day last year... it really did sound like a beast afterwards. hmm whats its like to have no work and nothing to do ...
1 - 12 of 12 Posts
