I have been trawling the internet but have no difinitive answers.
Can you help?
Here goes....
LPG 1.2 Corsa Van 55 plate.
almost 2 months ago had problem with gas switching from petrol and no heating. Turned out there was no water in the radiator!!
So I topped it up and added some anti-freeze/coolant.
Everything seemed fine. Although engine was a bit noisy for my liking, the oil light was permanently on and had trace of white cream on oil cap.
Today changed oil pressure switch which rectified the oil light.
At the same time decided to flush the cooling system. After adding distilled water and new coolant ran the engine for a while when it got up to temp there was foam coming from the expansion tank. So assumed there were still traces of the flush product so I flushed the system again a few times with water, refilled with distilled water and coolant.
This time no foam but did notice tiny bubbles in the expansion tank and water coming from the exhaust.
I took it for a 20 minute drive on my return there was no little bubbles in the expansion tank but still had small amount of water from exhaust.
There does not seem to be any water in the oil, there was an oily film on the first batch of coolant I flushed out.
NOW, I am wondering if I have a head gasket problem or possibly a water pump issue.
I have bought a bottle of Steel Seal and on the verge of using it but I just want to be sure what the problem is.
Any advice from any one with similar experience. Much appreciated.
Can you help?
Here goes....
