There should be some grooves in the sill to locate your jack if you are using a sill jack. If not you need to locate the front of the chassis legs just behind the wheel, I've found this seems to be the strongest area.
Cool I found a point just behind the wheel, where the sill jack would go I think.
I'm using a hydraulic jack so I reckon I'll find the point further under the body tommorow.
Can I put the axel stands on the sill jack points.
