1 - 20 of 102 Posts
Got pedal solid with engine off.
Goes crap again with engine on and when you actually go to test car?
Any ideas?
No ABS on it.
Spent so many hours now.. Started to wonder if I missed a seal somewhere or something. I'm sure I haven't
Sounds to me like you have a leak which is allowing air in.
Try in and around the MC. we had this problem in college and it was part of the vacuum that helped braking power that was messing it up.
Brand new master cylinder fitted last week
Nope, it's holding fluid just fine.
Which seal are you referring to regfo
I know it for A audi diagram, but its the same concept.. Number 3, somtimes can be put in wrong or slips when put on. I made this mistake when replacing one before.
I'm 99% sure that's in correctly was super careful.
This is same problem with original mc
Then one from Samos car
Now a new one
Think of all the parts in a braking system, then all the parts that haven't been changed yet. Logically, the problem should only be in the remaining parts. Unless there's a fault with a part that's been replaced already, or a part hasn't been fitted correctly. It's not had a mix of different types of brake fluid by any chance? .i.e silicone based fluid
Discussion Starter · #13 ·
Been using same stuffZ
Servo got replaced for 2nd hand one
Discussion Starter · #15 ·
Yup, changed the fitting that goes into the servo itself for a brand new item, and changed the hose up
Until the one way valve for a new one
IMHO looking like you have changed the servo and pipes etc, Id take drums off at the back and make sure pistons are not siezed and work way forward checking both brake callipers or do they defo work?
Wild guesses here trying to have a stab in the dark..
Drums rear shoes, slave cylinders are all brand
New.
I think you're correct Craig, I'm on the look out for a servo pipe for a Corsa sport now
1 - 20 of 102 Posts
