1 - 20 of 23 Posts
Dont know if any ones interested but always thought it wought be a laugh to have these,
pretty easy to make.
all parts from maplins. i have part numbers if you want them.
oh and :gay:
Discussion Starter #6
quick video of it.
Discussion Starter #9
PARTS LIST
(Maplin part numbers are show in brackets)
ICs
DIODES
BULBS
RESISTORS
CAPACITORS
1*NE555
(QH66W)
8* 1N4148
(QL80B)
6* 1K
(M1K)
1* 10uF
(FB22Y)
1* 4017B
(QX09K)
1* 3.3K
(M3K3)
1* 0.01uF
(WX77J)
LED Version
1* 8.2K
(M8K2)
1* 6.8nF
(RA43W)
dont know price but would have thought under £5
Discussion Starter #12
i have other electronic plans if anyones intersted
Car Battery Indicator -
Pulsing Third Brake Light -
Headlight Flasher -
Speed-limit Alert -
Park-Aid -
Automatic Headlight Brightness Switch -
Car Battery Charger -
Electronic car ignition -
Simple but reliable car battery tester -
Synchronized multi-spark module (SMSM) for Electronic Ignition Devices Automotive 12V to +-20V converter (for audio amplifier)
Yeah some of those could be quite useful, guess you would need a soldering iron and stuff to make all of these up and some technical knowledge?
Discussion Starter #15
yeah just basic soldering skillz is all you need.
i guess all you need is a soldering iron, solder and the parts.
power supply you just use your car battery.
ill get to posting more just gotta do parts list for them.
Discussion Starter #16
Semiconductors:
IC1,IC2 = 555 Timer, RS #276-1723
SCR1 = NTE/ECG5402, RS #276-1067, EC103A, MCR104, etc.
Q1 = NTE/ECG197, SK3083, TIP125, or equivalent
D1,D2,D3 = 1N4148, 1N914, NTE/ECG519, RS #276-1122
D4,D5 = 1N5400, NTE/ECG5850, RS #276-1141, or equivalent
Resistors:
R1 = 18K
R2 = 330 ohm (RS #271-1315)
R3 = 270K
R4 = 82K
R5,R6 = 1K2
R8 = 100 ohm (RS# 271-1311)
P1 = 50K, 10-turn
P2 = 10K, 10-turn
Capacitors:
C1 = 100΅F/16V (RS# 272-1016)
C2 = 22΅F/16V (RS# 272-1014)
C3 = 220΅F/16V (RS# 272-1017)
C4 = 10΅F/16V (RS# 272-1013)
Headlight Flasher -
Speed-limit Alert -
Park-Aid -
Car battery indicator is a good idea! Also like the sound of a pulsing brake light!
Could you do like a rev counter one with LED's? That possible? Would be sweet :thumbs_up:
Post up the battery Indicator circuit , i will have a go at that when im at work. Do you make these up Demon?
Discussion Starter #20
At last.
Better explaination
I have this built in to my battery and thought i could use it in the dash.
1 - 20 of 23 Posts
