1 - 12 of 12 Posts
Wonder if anyone can help, when i let my car roll, there seems to be a knocking noise coming from what seems like the driver side at the front, if i accelerate or beak it doesnt make the noise its only when i let the car roll?
fairly easy to check out, just have a helper roll the car while you check all the joints in the suspesion on that side, including the top strut. cost depends on what you find really, but if i guess that changing the strut top bearing being the most expensive (because you're basically stripping the strut like you would if you were lowering it) then it shouldn't be that expensive, especially if you check it out yourself before handing the keys in to a garage.
i think my corsa may have the same problem ... i took it for a raz on the local beatch and after i drove off my pal noticed a knocking liek a pst pst pst coming from the passenger side but it was only when i was traveling at 25 + or somthing i cheked the tyre ..fine .. no air escaping .. and im still lost as to what this is is it dangerous
nah dont kill it i need help on this one the knocking got worse last nite so i had a look at the top of the suspension nothing moving there ill chek weel bearing tonight let u no tomorow
1 - 12 of 12 Posts
