how do i get to put led's on the speedo clocks and the where the light swithces are im not sure how to get to them. im ok with the MFD/heater switches ive done them beofre was a right bar~steward IIRC.
Speedo clocks, you remove 3 screws on the surround lever it out (easier if you undo the 3 screws on the steering bit.
then undo 2 screws on the clock (left and right) and then put your hand under remove the old bulbs fit the new bulbs.
You might even have electric clocks rather than cable driven so should be even easier and you won't cut your hands up like me, kingsizeriz and lyds - i've still got the cuts :laugh:
