1 - 1 of 1 Posts
Did you get issue with Linksys velop Setup or Are you looking for the Process of Linksys velop Setup?
Here the solution of your problem. Without thinking twice move further and Setup your Linksys velop by
own.
You have bought a new Linksys Velop and first question arises -How Linksys Velop Setup
Don’t need to worry!!
We are here for you, we will explaining here all Setup details about Linksys Velop.
Basically, Linksys Velop is a whole-house Wi-Fi System or mesh-router system that makes use of several
routers to create and convey strong and reliable internet signals throughout the house.
Note- To get access Linksys Velop, you need the IP address of your device, the username and password
is must. You will find such information in the Manual of your Linksys Velop, but if you are unable to find
the information in the manual for your router or most of the time we are interested to read the whole
manual.
For your convenience, here we are explaining the solution for you. This post helps you how Linksys velop
setup using the router's IP address and default login info, allowing you to manage your wireless
network.
But before moving toward to solution part means setup process you should need to know about the
basic requirements that would be helpful for you to Login and setup Linksys velop.
Basic Requirements for Linksys velop Setup
Collect these things to login Linksys Routers, after collecting these things you can login and setup Linksys
velop by your own.
 Linksys Router
 Modem
 Ethernet cable
 Tablet, computer, or Smartphone
If you collecting these things after that, you are able to login your Linksys velop. Without these things
you cannot configure your Router successfully. So, complete these things after that go ahead.
Most of the time people did mistake here, they start login and setup Linksys velop directly before
connected with the network. So, here we are explaining the brief information about the connection of
Network. First you need to check the network after that you can freely move toward to Login and setup
process.
Connect with the network
Here we are trying to explain the information about the network connection, steps are as follows:
Use any device such as desktop, laptop or smart phone to connect your Linksys Network. You can
connect with the help of wired and wired network connection; if you are trying to connect with wireless
network then you can connect direct whereas a wired connection requires an Ethernet cable. Try to
connect with default password, if you don’t know the Linksys router default password, you can connect
with the Ethernet cable.
To reach the setup page, you must be connected first to the Linksys network. Make sure, you are
connected with the network, after that move to the next step.
Steps for Linksys velop Login and Setup
Follow the below steps to Login and setup Linksys velop, with the help of these steps you can login by
own, here are the steps:
 Initially, open any browser according to your choice such as Internet Explorer, Google Chrome,
and Mozilla Firefox etc.)
 Secondly, type 192.168.1.1 into the address bar after that click on Enter.
 Next, you will be asked to type the router's username and password to log-in Linksys velop.
 If you don’t remember Username and password that you have change the login with default
login credentials. So, leave username field as it is (means blank)
 For the default password, you need to enter your password in the empty field. If you haven't
changed your password from the factory defaults, type “admin” in the password field.
 Click on Login button to login Linksys velop.
Make sure with these steps you can easily login your Links velop.
Linksys Velop Setup in Bridge Mode
Do the following steps to Setup Linksys velop:
 Firstly, open the Linksys app and go to the dashboard.
 After that, tap on “Menu” icon.
 Next, click on “Advanced” settings and then, tap on ‘Internet Settings’.
 Now, click on “Connection Type” or moves to “Internet Settings” page.
 Now, click on change the connection type to “Bridge Mode”.
Note: If you are not able to see Bridge Mode option, then check in case the app is upgrade and Velop
nodes feature the up-to-date firmware.
 Furthermore, click on “Save”.
 Last Tap on “Enable Bridge Mode”.
After implementing these steps you can successfully Setup Linksys velop by own.
Note- when you are unable to login with Linksys router the, check your internet connection first. If
internet connection is not stable then, you can’t login successfully. Always check internet connection
first after that trying to login or setup your router, use high speed internet connection. If you found your
internet connection is not stable then you can’t login even after several tries. So, you have to wait for
the stable internet connection and try to login Linksys velop again.
In case after doing these all steps you won’t login then, reset your Router. Read below steps to reset
your router.
 The First step is press and holds the reset button.
 Next, release the reset button after the modem lights start flickering (10 to 15 seconds).
 Wait till 3 to 5 minutes for the Internet light to turn green.
 When green light blinking then, try to connecting Internet again.
 By doing these above steps you can definitely login Linksys Router.
Positively With these steps, you can login and setup Linksys velop by own. In case, if you are facing any
kind of issue with Linksys velop such, Linksys velop setup issue, Linksys velop login issue, and Linksys
velop not working issue feel free to contact Linksys technical support phone support phone Number and get the proper resolution for your problem.
1 - 1 of 1 Posts
