All bits near maidstone in Kent. can be collected or posted at buyers cost
PM me for any questions!
Uprated bits -
PIPER adjustable vernier pullies for c20xe. As new. Only been used for a setup never run - £140
C20XE uprated 421 manifold (mild steel possibly janspeed/ashley/sportex). alot larger, good gains and rare - £135
Genuine irmscher front splitter. Post 97. Comes with front bumper aswell in black - £100
Irmscher sideskirts (one damaged but repairable) - £45
CARBON FIBRE centre dash surround (surounds the centre vents/fan controls) - £50
Rear tinted windows (back 2 and boot). Boot window can come complete with boot - £50
60mm lowering kit (unsure of make will check). Shocks and springs all round - £90
x14xe/x16xe uprated inlet (powerbox) complete - 80
x14xe/x16xe uprated 421 manifold - 100
Corsa powerboost valve - £35
Sport interior - £50
Corsa exhaust system with twin exits (reciept for £350) (one ovalish exit each side) - £45
Bodykit rear bumper - £10
Fox racing mulitspoke alloys. Graphite gray 15" with tyres - £160
SRI dials with red needles - £20
Tigra/sport type dials (deep with orange needles) - £20
Full set of black doorcards - £35
Stubby ariel - £5
Smooth door handles (no locks) - £20
LED 3rd brake light (very easy to wire in) - £10
1x REAR GSi jacking point cover - £15
OMP black 13" steering wheel - £35
REVOTEC boost gauge built in to corsa heater vent. Comes with vent so fit straight in (looks really smart) Ideal for LET/diesel turbo - £30
New autogauge oil pressure gauge - £20
Water Temp gauge - £20
Tinted Voltage gauge - £20
New autogauge oil pressure gauge - £20 (all gauges come with everything needed to fit and work and are backlit)
Enclosed type carbon fibre airfilter/induction kit - £20
256mm 2.0 vented front brake setup (everything needed) - £40
Wiper motor - £5
steering wheel - £5
Rear lights - £10
Headlights - £10
Fans - £10
Black mirrors - £10
tigra/sport clocks (grey surround with orange needles) - £25
GSi/TD thicker ARB - £10
Corsa ARB - £10
New fuel filter - £5
Standard rear shocks - £10
Standard front shocks - £10
5door grey parcel shelf uncut - £10
Interior light (Has on/off switch built in) - £5
Sport centre caps - £10
16v fuel pump - £10
corsa rear water pipe - £5
1.2 8v ECU - £10
F15 gearbox - £40
Gsi/sport front brakes. complete set - £10
Corsa 8v rad - £10
Late type bolt in battery trays - £10
Good corsa centre section - £15
Corsa petrol tank - 20
MFD (date/time/temp) - 10
Corsa doors - £15 each
Corsa front wings - £10 each
Post 97 front bumper - £10
Gsi spoiler - £15
FSE powerboost valve - £25
2x 5mm alloy wheel spacers (perfect bore size for corsa) - £10
Denso large oil cooler in black - £20
Spax RSX front coilovers - need a new seals/rebuild as oil has leaked out and no springs but have adjusters - £25
V6 throttle body (3 stud) - £15
Pipercross oil/small breather - £5
c14se inlet - £10
c14se cam cover - £10
c14se coilpack - £10
c14se starter - £10
LOW MILEAGE X16XE SPORT ENGINE (Really good engine - quiet, pulls well). Comes with loom/ecu/gearbox/mounts etc - £175
x14xe/16xe ac pump - £15
x14xe/16xe Alternator - £15
x14xe/16xe bottom pully/sprocket - £10
x14xe/16xe starter - £15
x14xe/16xe SACHS clutch - £20
x14xe/16xe cambelt tensioner + pulley - £10
x14xe/16xe loom - £20
x14xe/16xe crank sensor - £10
x14xe/16xe upper inlet - £10
x14xe/16xe lower inlet - £10
x14xe/16xe cam cover with oil cap - £10
x14xe/16xe camshafts with pullies - £20
x14xe/16xe cambelt cover (upper+lower) - £10
x14xe/16xe alloy sump - £10
x14xe/16xe coilpack - £10
x14xe/16xe TB - £10
x14xe/16xe EGV valve/motor - £10
x14xe/16xe injector mini loom - £10
x20xev starter - £10
x20xev alternator bottom mount - £5
x20xev bottom pulley - £10
x20xev knock sensor - £10
x20xev crank sensor - £10
x20xev cambelt pullies/tensioner - £10
x20xev breather tube - £5
x20xev NEW stem seals/cam seals/rocker gasket - £10
x20xev flywheel - £10
c20xe AFM - £10
c20xe metal L peice - £20
c20xe rear water pipe - £5
c20xe starter - £15
c20xe late inlet hose - £5
c20xe fuel rail/beige injectors - £15
c20xe inlet manifold with TB + 3pin TPS - £15
c20xe TB with 6 pin tps - £10
c20xe thermostat with housing - £10
c20xe exhaust sheild - £10
c20xe BRAND NEW headbolts - £15
c20xe standard cams - £20
c20xe exhaust cam - £10
c20xe disptick/breather tube - £5
c20xe GM oil pump - £10
c20xe cambelt backing plate - £5
LOADS MORE XE BITS JUST U2U ME...
JBL 15" 1000w sub - £25
JBL GTO4000 600w amp (works but one plug is a bit dodgy could be fixed easily) - £20
Homemade thick MDF box for 2 15" subs - £20
Need anything just PM me as i may have it :thumbs_up:
Uprated bits -
Stubby ariel - £5
Wiper motor - £5
steering wheel - £5
Rear lights - £10
Headlights - £10
Fans - £10
Black mirrors - £10
Corsa ARB - £10
16v fuel pump - £10
1.2 8v ECU - £10
F15 gearbox - £40
Corsa 8v rad - £10
Gsi spoiler - £15
c14se inlet - £10
c14se starter - £10
x14xe/16xe TB - £10
c20xe AFM - £10
c20xe starter - £15
