hey guys i know this has been asked a few times but looking through the other threads i haven't been able to find a straight answer or other peoples symptoms for the problem are different.
Right well heres the details.
This happens when the engines warm, and i get now warning lights like allot of other people say they have had but when im accelerating i loose power. Well its like im accelerating my revs hit between 2 and 3 thousand and suddenly i stop accelerating for a few second then it quickly picks up and jerks you back up to speed. Ive noticed that if i start with higher revs it doesn't do it, i mean from idling at lights, not turning her on. But if im cruising at 30 in fourth it sometimes does it drop it to third it doesn't do it.
Ive heard the idle control valve, egr valve and the maf been thrown around plus the fuel pump and fuel filter, or even a blocked air filter. The reason im starting this thread is to find out how to go through all these possible causes and find out which, if any, is the culprit without having to replace them all.
Your probably fed up of reading posts like this but im desperate i have tried google and searching for info myself.
thanks for any and all help.
