I have a 56 plate corsa twinport. I had a pretty major leak in my clutch housing so I had it changed in the garage. I was advised that not every part needed changing so had the housing and slave cylinder change undrr advice from the garage. With in a week the clutch had stopped working. I returned to the garage where after a few days they decided they couldnt fix my car, leaving me with no car or money. I then took it to a different garage explaind the situation to which they changed the master cylinder and the pedal. After a week the clutch stopped working again. I returned to that garage where the bleed the clutch and I was on my way. Again with in a week the clutch had stopped again. On returing to the garage they tried to bleed it again and nothing happened it didnt seem be getting fluid from the resoviour. The tried power bleeders and still nothing. Ive been told its probably the slave but there are no leaks anywhere. I feel like im being ripped off and need some advice please help
Sent from AutoGuide.com Free App
