1 - 7 of 7 Posts
I have a silver vaux corsa b sxi in fairly good condition, i am aiming to work on it during the summer. what engines other than 1.2 would fit in its place? i also want to work on the exterior without big body kits. Any ideas:D
:welcome:
Looks wise - get the badges off and look for some decent alloys ;)
To answer your engine enquiry, any of the corsa engines such as 1.0, 1.2, 1.4 and 1.6 will be a direct swap. You can also put in the x18xe1 small block 1.8 onto the standard corsa mounts which is why its getting a more popular swap although it requires a little tinkering to make it fit. You can also fit the c20xe 2.0 and c20let 2.0 turbo engines using the correct fitting kits so there is plenty of choice depending on your budget and mechanical skills.
1 - 7 of 7 Posts
