COMPLETE ENGINE:
Complete low mileage C20LET engine with ecu, loom, manifolds, turbo, clutch, flywheel, radiator, airbox, pipework, intercooler. It already has the single vee alternator and power steering pulley so ideal for a transplant if you're not cool enough to have a Calibra. £950
Video of engine running http://s188.beta.photobucket.com/user/benn859/media/Selling/VIDEO0057_zps5578c0e5.mp4.html
PART ENGINES:
C20LET tall engine, done 84k from Cav Turbo. Excellent runner. Consists of block and head timed up with all internals, oil pump, water pump and sump. No ancillaries £500
Reconditioned Coscast cylinder head, brand new hydraulic lifters, valve springs, valve stem seals, all valves reseated, brand new nuts and bolts & all de coked £350
Bottom end consisting of block, crank, rods, pistons, oil/water pump, sump. £400
UPGRADED PARTS:
Bits from this picture...
Distributor complete with cap, hall sensor and rotor arm £40
KKK16 turbo with brand new forge turbo actuator & also brand new penny valve and lever on turbo £250
Bailey dump valve with silicone hose £50
3" TX Autosport downpipe, cost £179 new, yours for £140
C20LET wiring loom £125
Stainless steel oil cap £20
C20LET fuel rail with regulator £20
C20LET AFM £60
Evo 6 front mounted intercooler with hard piping £70
Polished throttle body inside and out (enlarged and reworked), not very old £80
C20XE inlet cam & C20XE exhaust cam plus, this brand new vernier pulley
£100
Brand new C20XE/C20LET fuel rail blanking plate
£20
C20XE/C20LET silicone breather, brand new
£10
4x brand new boxed Bosch 0280150558 green injectors
£125
C20LET EDS/Regal phase 3 board and power wheel kit. brand new unopened
£300
Phase 2 C20LET ecu
£180
Z20LET injectors (ideal C20LET upgrade) £45
2x sets of Magnecore KV85 8.5mm ignition leads
£80 per set
XE/LET Head stud kit. Re-usable. Cost £120 new, yours for £60
Polished oil cap, fits 8v, XE, LET, 8v smallblock etc...
£10
FSE adjustable fuel pressure regulator with pipework
£25
3" tophat
£30
Baileys DV26 from above picture, with silicone hose £50 Got one in black too for same price.
KKK16 Turbo with upgraded actuator, excellent condition
£150
Stainless AFM to turbo pipe with joiners
£30
Cone filter above £10
STANDARD PARTS:
If you need any standard parts not listed, just ask
Brand new genuine Bosch C20XE/C20LET idle control valve
£80
Standard C20LET ecu £125
KKK16 exhaust elbow
£10
F28 rear mount
£10
Brand new Gates cambelt kit, square tooth, boxed, with rollers and tensioner
£40
C20LET inlet cover, un-cut
£20
3x complete distributors with caps, rotor arms and hall sensors
£30 each
C20LET bosch yellow injectors £40
Black plastic spark plug cover £10
Airbox £15
AFM to turbo pipe £10
Ignition coil £20
No offers thanks
