Hi all! I'm new here and kind of stuck massively with my car!
Car Spec- Vauxhall Corsa (1999) 1.2 16v
Issues- My car has a lot of trouble starting, i have been told that it could be many things and tried my hardest to get the issue sorted but have now ran out of ideas. The car turns over fine, there are no problems with the battery or starter motor as they are relatively new. The crank sensor has just been replaced and the 2 fuel pump relays hiding behind the glovebox have also been replaced. The engine management lights isn't permanently on, it will come on every now and again, and when it does, it seems to drain the power from the car, until i take my foot off the gas and reapply pressure.
If you have any suggestions as to why this is happening please help me out, i need the issue fixing as i am a support worker for people with disabilities and need my car for the job. I am not currently in a position to go out and buy a new car as i have other commitments.
Additionally, the water pipe leading from the engine to the radiator burst the other day and i have replaced it with a new pipe and used hose clips to firmly keep it connected. There is no signs of leaks from the 3 parts of the pipe i hose clipped on.
Possible suggestions are great!
