Hello,
I have a 2003 Combo van with a 1.7 diesel engine. Twice now I've had no brakes. Both times the symptoms were the same. The pedal would not move, no matter how hard I pushed, and the van wouldn't stop. It as if there was some mechanical obstruction stopping the pedal moving, or a blockage in the hydraulic system at the master cylinder.
The first time the local garage changed the master cylinder and changed the brake fluid. But now it has happened again. On both occasions the problem cleared itself after a few moments and the brakes reverted to working perfectly normally.
Any ideas? Is this a problem that anyone recognises? I won't feel safe driving it again unless I have confidence it is fixed.
PeterC
PeterC
