Spent most of the day changing the timing chain on my 2004 1.2 Corsa, a job I'm doing for the first time and always something I fancied doing.
The fit went ok and I was quite pleased with myself, until after tightening the crankshaft spocket bolt.I decided to rechecked the valve timing, cams locked and T.D.C. set, only to find that the timing marks on the bottom pulley are to the right of the marks on the timing cover by about 10 deg.
When I first fitted the chain, ok the cover wasn't on but I'd make a mark around where it would be. Strange thing is now, when I remove the cam locking plates and move the crankshaft backwords towards where the T.D.C mark is on the timing cover, according to the manual, the crank locking pin doesn't go cleanly in the hole, you have to turn the pulley to the right.
Are my camshafts a tooth out and is T.D.C with the pulley mark just in front on the mark on the timing cover and not just after as mine currently is.
When I try and line the mark on the crankshaft pulley with the mark on the timing cover, the crankshaft locking pin won't go in the hole, yet when I move the pulley 10 deg clockwise the pin falls in the hole.
Tomorrow will be an interesting day, trying to figure out what I did wrong, unless somebody on here can help.
I can't continue with the rebuild until I know the timing chains are correctly aligned.
