Hi, im 17 and just had my first car a couple of weeks ago. The past week the oil warning light has been coming on at low speeds after having been out for around 30mins. Flashing when in first or second gear going slowly, it was ok at higher speeds of 30-40 but yesterday it was foing the same thing thoighout the journey after about 30mins no matter what speed. I replaced the oil pressure switch and it hasnt changed. There is a small leak, cant see where from, ive been told the most likely cause is a bad oil pump which will need replacing? However they also said it could be the oil filter being clogged up? Anyone know if this sounds right? And wgat sort of price im looking at? Also about 30 mins after driving a rattleing comes from under the bonnet, i presume this is the timing belt as there is no oil getting to it?
Its a 1.0 corsa club 2002 by the way
Any help would be muh appreciated also sorry about spelling, typeing on a small phone isnt the best...
