I have a 1.2l 2003 petrol model. Ever since I had an oil change, the oil low light comes on quite regularly. At the moment it is on almost permanently and flickers when I'm driving. There is oil in the sump.
The car has always been thirsty on oil, and doesn't sound too good if you use cheapo oil either. At the last MOT the fella told me the oil filter could do with replacing.
The oil is not all mayonnaisey like it would be if it was the gasket (I've had that problem in a previous car!) There's no puddle under the car either. The engine does not appear to overheat either.
Any suggestions? Faulty sensor? Inadvertently put too much oil in? Is the car ok to drive (I'm constantly checking the dipstick)?
