Hey, I don't know much (anything) about cars. I have been googling my evening away tonight to solve the symptoms of my car. Today I was driving my usual journey to work, when about 6 miles in my engine light came on and the engine began to judder/shake. The gas pedal felt smoother for some reason also.
I parked it at work and left it. I drove home with the engine light on with what seemed like little/no engine judder. I got home and re started the car and the engine light has gone off..
Could this be lambda Sensor? Fuel Injector? Spark Plugs?
Any advice would be helpful.
I drive a corse life 16V, so that's a corsa C.
I recently had a mechanic repair the engine coil and water pump on the car.
Welcome to the Forum.
If the car is anything like due for a FULL service, I would tend to do that first of all.
Suggest that you then clear any fault codes, drive the car and see if the problem returns, if it does, you need to check for fault codes again - any that are there then will be new ones and should point to the cause of the problem.
Regards
