Hi all, new here so bare with me on my first post,
I currently own a Corsa C 1.2 SXI 55 plate as my first car. Mileage is low, currently 50k. Its a lovely first car and I use it all the time for work etc. However it recently developed a problem with idling and acceleration.
The Engine Management Light has appeared also and is driving me nuts. I hate it! The car struggles to accelerate, and by this I mean I have to Rev it more or otherwise it may stall when pulling away. This only happens when I first start the car and the first few start and stops otherwise later on in the journey it is fine.
The weird part about this is the Engine Management Light appears and disappears occasionally and I believe this is something to do with the restarting the car 30 times without the problem or something, idk.
However, when the Engine Management Light is off, it is perfect! There is nothing wrong with the car at all, runs spot on accelerating and pulling away, as soon as the light comes back, bam, runs rough again.
Fuel consuption is awful too I believe, I'm currently doing about 200 to the tank, which is about 18 miles to the gallon or something? Bad at math sorry! I do short journeys but I was expecting more than 200 to the tank.
I have read on-line and looked at the possible causes:
MAF
Vacuum Leak
Lambda/O2 Sensors
I replaced the MAF with one from a scrappy and nothing improved really. It still runs the same, either meaning both of the MAFs I had are crap or it isn't the MAF at all.
I have sprayed Carb cleaner all over the Vacuum Hoses in the Engine, and the car didn't rev at all and I couldn't find a leak in the hoses.
What do you guys suggest? Changing MAF again? Lambda Sensors? Please help!
MAF
Vacuum Leak
Lambda/O2 Sensors
