Hi
My corsa has intermittent stalling/revs dropping that cause these two error codes to be logged. I'm going to get the crankshaft sensor replaced but wondered if the 0130 could be linked to this dodgy sensor? The errors happen at the same time as each other so appear linked somehow.
cheers
jonny
Ignore the P0130 for the time being. Since the O2 system is a feedback system anything that causes the exhaust gases to be out of parameter will throw an O2 code - usually fixing the primary problem sorts the O2 issue.
If you still get the P0130 codes after you've replaced the crankshaft sensor then it's time to look into it.
