hey im getting an error code P0650 circuit malfunction and indicator lamp (ml) control im wondering would this be down too the actual rear driver lamp is i have noticed its extremely dim compared to the other any help is appreciated :)
just found this, might help
Generic OBD Error Code Details for P0650
Malfunction Indicator Lamp (MIL) Control Circuit
What does this mean?
OBD Code P0650refers to
Malfunction Indicator Lamp (MIL) is located on the instrument panel. When the ignition switch is turned ON without engine running, MIL will light up. This is a bulb check. When the engine is started, MIL should go off. If MIL remains on, the on board diagnostic system has detected an engine system malfunction.
Symptoms
Possible sumptoms of OBD code P0650
- Engine Light ON (or Service Engine Soon Warning Light)
Causes
Possible causes of OBD code P0650
- Harness or connectors for the MIL circuit is open or shorted - MIL bulb may be faulty - Faulty ECM The Error code is generally activated on detection of the following conditions: - An excessively high voltage is sent to ECM through the MIL circuit under the condition that calls for MIL light up. - An excessively low voltage is sent to ECM through the MIL circuit under the condition that calls for MIL not to light up.
think it might be to do with the actual tail cluster itself i just took it apart and its very corroded looking so will replace that when i can get a spare as to the error code it could very well be service engine soon its just coming up on 70,000 thanks for the help tho :thumbs_up:
