am busy striping my new wheels am going back 2 bare metal and am useing paint stripper and a wire wheel on a drill takes a while but works:thumbs_up:right got some new cav slabs thanx to martinlird lol
they need a lil tlc so should i strip the paint off of paint over it?
and if strip the paint, how?
does nitromors damages the alloy finish or was it ok?When i did mine i got some nitromors, about £7 a tin, slap that stuff on the alloys and leave them 15 mins to soak. The paint will just come straight off, then just scrape it off, clean it up, sand down till really smooth, then put on your primer and stuff.
haha!yeah heard its nasty stuff lol
ill give it ago,im gonna paint them when mums on hol so i can put them near the fire to dry quicker lol
alloy primer.. lol.and then is normal primer ok?or do you get like alloy primer?
this would be ideal, but its generally expensive and to be fair, the results compared to using normal primer are minimal. If you're anal, and dont mind spalshing some cash, etch primer would be best.i thought with it being bare alloy you will need to use etch primer
yeh, waht ryan says is true, etch primer is the peoper thing to use for the job. The initial finish wont really be affected, its the whole lifespan and the way normal primer can chip off easier than etch primer does.You will still get a decent finish with normal primer, im just stating the facts about etch primer.
