Hello all, I can't find a tutorial on this so was wondering if someone could show/help me. I've got a Corsa C, and I'm bored of the interior therefore I'm thinking of painting the centre column the display dash dome, surround around air vents, fascia and heater control faceplate. How do I go about this I want to paint it do I just literally lightly sand it down, use grey primer, spray red gloss then lacquer it up. Also how do I remove the whole dome and surround around vents an heater control panel.
Been so long since i did it. Basically on the C pop the vents out.
behind should be some screws to remove the fascia around vents. As for dome once Fascia is removed it has a couple screws holding it in place and a wire connector on the back.
You can then remove dome and gently pop clock out.
Pretty sure the knob part is popped off with small screw driver
