can anybody help. i have a 1.0 02 corsa and on sunday servo went. fitted new one. brakes ok as passed mot yesterday but the car keeps trying to stall/cut out.
If there was no problem with the engine before you changed the servo, there is quite likely a vacuum (air) leak on the connection to the servo.
Suggest that you inspect the pipe and its connections.
If you are happy with these, remove the vacuum pipe connection and make a temporary seal on the ENGINE side of it (put your thumb over the end) if the idle then improves, there is probably a leak in the new servo.
Regards.
