I was wondering if the Corsa B EPS used a speed sensor? If so where is this located? Thanks Dan
D danielpalfre · Registered Joined Feb 15, 2011 · 432 Posts Discussion Starter · #1 · Apr 16, 2013 Only show this user I was wondering if the Corsa B EPS used a speed sensor? If so where is this located? Thanks Dan
Rob · Premium Member Joined May 25, 2010 · 8,351 Posts #2 · Apr 17, 2013 Only show this user it does, either on the gearbox speedo output or from the ecu directly.
