1 - 1 of 1 Posts
Very hard to say without hearing it. A rattle could be pre-ignition, or worn components (timing chain, valve gear), or a loose engine mount, or exhaust.
It could be something as simple as a dying AFM which is causing too lean a mix, that will cause the pre-ignition rattle and the EML coming on. But that's just a wild guess. You're right to invest in opcom and track it down properly before spending on parts.
(If it is the AFM then don't buy a cheap one, they are useless. It has to be the genuine one.)
1 - 1 of 1 Posts
