Hi,
I've got a problem with my Corsa's air conditioning system.
When I press Air Con button the engine revs increase as the compressor switches on.
However the air does not get cold at all + cooling fan in the engine bay does not switch on as it should do.
I've checked relevant fuses on the car & also checked the refrigerant with a gauge- shows 150psi on the low side when the AC is on and 150psi when off.
Anyone know any other ways to check/ repair it- I don't really want to go to a garage if it's only a simple fix.
By the way, the car is a Vauxhall Corsa D 1.0l EcoFlex 2010 A/C.
