1 - 9 of 9 Posts
Basically my car with its baby engine 1.0 12v is a bit strange. Some days it run great, idle about 800rpm. Today i drilled the airbox (and indeed gives a great sound) But stil it sometimes dips down to about 600rpm. It wont stall, but does indeed feel like its going to. Now is there anything i could? do you think the changing of plugs, panel filter etc might sort the problem
hi pal the bosch air flow meater is a commen fault on the 10 and the 12s it will make it idle low and run flat make shure the plug is in tight if you have been messing with the induction.
ok m8 cheers ill have a look. If in doubt how much they to pick up if i need to get a replacement??
Easy problem to fix, its likely to be the ICV (idle control valve) of AFM (air flow meter) not a difficult job really :thumbs_up:
My corsa does that, when i start it up it takes a couple of goes to get it going... and when it does go, the idle seems pretty low and it seems to struggle a bit puilling off...
1 - 9 of 9 Posts
