Please could somebody help, it's driving me up the wall.
I have had a leak in my car (Drivers side footwell) which my dad has hopefully repaired this morning.
Unfortunately, when I got back home, I turned the engine off and the radio stayed on - which has never happened before. The only way to turn it off now is to manually press the button. I then noticed the panel was only showing the time, date and temperature. The date usually changes to the radio station playing after a few seconds. Also, i can't use the panel at all. I tried pressing settings but this also doesn't work
I don't understand why this is happening. The time and temperature are changing ok so it's not like the panel has stopped working.
Please can somebody give me some ideas?
Thank you
Hi there, sounds strange, cant really help you, but do you think its anything to do with water getting in the car, i suppose that was the servo bracket, seems like a standard feature with Corsa's lol..
I think the radio has a permanent feed for the memory and a switched live from the ignition acc terminal..i suppose it could be a fault on the ignition switch..
first thing i would try is disconnecting the battery for 10 minutes and try it again...does wonders sometimes..have you touched any wiring?..
Hope that helps...cant think of anything else, suppose could have a radio fault....from Fred in Essex.
Thank you
