1 - 20 of 26 Posts
hello all , had this annoying rattling problem for about 2 months or so. but it only rattles when I go at low speeds or move off from stationary, it's still doing it. what could it be? O yeah it's a corsa sport 1.4 1.6v :confused:
It might be your heat sheild on your exhaust manifold. They're tacked on with a couple of welds and these usually break off after a while due to corrosion. It's a common fault.
Check that and if it doesn't solve it let us know.
also, heatshields can be binned, u dont need them :)
it's defo not the heat shield (exhaust manifold) cos it's brand new, the first corsa I had rattled cos of the heat shield and that drove me nuts lol. I'll have a look at the cat's heat shield , also is it possible to tighten up the heat shield on the cat, without having to buy a new cat?
appreciate the help thanks
had a look at the cat and cat heat, shield nothing loose very sturdy. still rattling though, so it's going into garage to be looked at (vauxhall) , I'll let ya all know what the rattling was.
OK cheers, that would be good for future reference.
I had the same problem with mine. My problem was where 2 parts of the exhaust joined. (It was in the middle slightly towards the front of the car, not sure of the names, I THINK it was where the downpipe joined the centre section) There were 2 bolts holding the 2 parts together, the piece of metal that the bolts bolt into had rusted away so 1 of the bolts was loose and not holding the exhaust at all as it was bolting into nothing, the exhaust was being held by 1 bolt. As a result the bolt and exhaust were rattling becuase of the vibration, took it to a garage place and they cut out the rusted joint, and put a piece of flexipipe in. Sorry for the long post and sorry if you didnt understand any of that, I know I go on a lot lol.
Exhausts are right fidgety things.
Right then found the rattling problem .............. it's got something to do with the V-BELT, the part in general is hitting off something and thus making a rattle (of course when the engine is on)
sounds like a stone or something in the alternator then, mines been doing that since day 1 about 3 years ago, even took it off and tried to shake it out, no joy. doesnt give me a problem though, although with you it might be down to how much and how loud it is rattling before it really drives you nuts.
By the v-belt I'm guessing you mean auxillary belt?
I had a wierd noise coming from mine before and it turned out to be the waterpump, it was knackered. I replaced that and it was sorted.
It could be the cat itself. The monolith can breakdown in time and rattle about inside the cat housing. Do you have any performance issues? Usually when the cat collapses like this, it blocks the exhaust stream and can turn a normally sprightly 1600 perform worse than a 3 cylinder.
1 - 20 of 26 Posts
