I have here with me a OMP rear corsa B strut brace.
I've just fitted my bilstiens rear shocks in however to tighten the top nut you have to place an Allen key in the middle and tighten the 16mm nut on top to prevent the center rod twisting.
When I came to fitting my strut brace I found that there would be no way that I could tighten the brace on the suspension rods. What should I do or is there anyway of doing it?
Shall I cut the sides off and use the OMP bar to weld it to the chassis from side to side or does it have to be directly fixed on to the suspension rod that goes down for optimal stability?
