1 - 8 of 8 Posts
I used to also undo the 22mm centre bolt, and hit it from behind to remove. This resulted in a collapsed steering wheel column and hit it too hard.
So I bought one of these
about £15
Or cheaper on eBay etc..
Took airbag off (two torx screws) make sure you disconnect your battery for a while first,
The undid the 22mm bolt.
Put the puller on.black piece goes on the centra (that you removed bolt from) two Silver prongs hook onto the wheel.
Then you tighten the black part of puller with a socket and here's a video
Showing what happens
http://i121.photobucket.com/albums/...D1-828D-511FA1981C5F-266-0000008B4C50C5F3.mp4
I'm going to buy this straight away - some guys came down to take bits off my spare car and needed to take the steering wheel off, they must have spent a whole hour bashing at it and eventually after a painful experience it came off.
Thanks.
I believe this is the item?
It is. Actually thought was cheaper in halfords. Made by Laser, maybe trade discount took alot off.
I've got one of these in my garage, I think I paid £17, £15 posted or if you cover postage ill happily let a trusted member borrow it :)
Sent from my iPad using Tapatalk HD
1 - 8 of 8 Posts
