1 - 20 of 23 Posts
Yes, loads of people :)
3 door I assume?
Bash pins at top and bottom from
Hinge, and small one in middle.
Twist the plastic plug and pull. Job done
A hammer and thin drift work well. You'll need someone to take the weight of the door as you remove the hinge pins. Undo the electrical connections, then do the restraining strap, then the hinge pins.
It's quite important to keep the door level as the pins come out - otherwise they'll jam.
Much much easier with two people.
Open the door.
Look at the hinge's.
Assess the hinge's.
Remove the clips from the hinge's.
Un-screw the block.
99% of it is self explanatory
Open the door.
Assess the hinge's.
Un-screw the block.
Be nice :) It's worth double checking beforehand. Especially for hints and tips.
Sorry, tried be nice. It's not for me.
Reverse into lamp post with door open - done - and only requires 1 person
Reactions: AJ
Brilliant!
Twist the plug, then pulls out
:mad:
1 - 20 of 23 Posts
