1 - 6 of 6 Posts
Hi
I need to remove the peice of trim where the tweeter sits, behind the wing mirror, inside on a corsa C. I didnt want to just pull it off.
you need to pop out the leccy window buttons,there is a screw behind the handle, and there should be on behind the wing mirror like you siad. in this way its similar to corsa B's, anyone else input what else there is on C's?
Thanks for that!!
so thats how you get the door card off! Does any one know if I can replace just the inside door handle, on the door card? The bit the electric window switches are? I went to vauxhall and they said you have to replace the whole door card at £90.
What is wrong with the corsa C plastics! They scratch and dent so easy its unreal!
Thanks!
Tell me about it!
The driver side door card on mine is really badly scratched!
I think I'm going to buy a Haynes manual before I remove mine!
1 - 6 of 6 Posts
