1 - 1 of 1 Posts
I am in the process of changing the rear seats of my Wife's 2001 Corsa-C SXI.
The problem is the TORX bolts (50mm?) that hold the seat belt buckles have stripped after only being slightly loosened...They are very tight.....I guess because the end threads of the bolt are corroded having been exposed to the elements where they protrude through the captive nut welded to outside of the car body.
First one then the other one have both stripped.
I could just saw the bolt heads off but then I still have to get the threaded bit out before I could use new bolts.
What is the best way to remove them whole?
Has anyone used a Irwin Bolt Grip Nut Remover Set?
1 - 1 of 1 Posts
