So my car stopped running about 2 weeks ago. Most likely because it was on its way out (white smoke from exhaust, never any coolant in resevoir, oil in expansion tank etc) and i just hastened that by pouring some steel seal in as a last ditch lazy effort to keep it going. and the following morning it just refused to run. Checked oil and it was practically empty so filled it and after a few starts it choked back to life but i had to spend 5 minutes trying to get the engine to crank. Eventually it stopped doing that altogether...whoops.
I've got a new car now so i've decided that instead of scrapping the corsa d as a non runner i'm gonna attempt to repair the engine for the sake of learning and hopefully sell on to recoup some of the money.
I've started off by removing the airbox, electricals and rocker. Pulled out spark plugs and saw oily residue which from what i read can be a likely reason for HGF.
I've attached some pictures. All 4 spark plugs had oil with 1 and 4 being the worse as well as the pictures of the black oil build up of their pistons?
I'm at the point where i'm trying to remove the inlet manifold before i tackle the water pump,pulleys and timing cover. Hayes mentions to remove bolts but doesn't state where and how many (i've taken off the obvious 4 from the front but can't get around the back to see if there are any there) the EGR valve has been disconnected as i know that connects the manifold to the head too. Can anyone help a guy out?
