Hi,
About 6 months ago the reverse light and cigarette lighter controlled fuse blew on my Vreg Corsa B, i replaced the fuse and it blew again straight away.
As well as this the speedometer also has stopped working with no indications on the fuse board etc. as to why this would happen.
A friend suggested the problem with the speedo was the outward gearbox sensor? can anyone help?
thanks in advance.
if it blows straight away then theres a problem possibly a short circuit somewhere lot of current going through it investigate problem try again or disconnect each thing then connect 1 at a time and find out what it is thats causing it so take ciggerette lighter out test it etc. long process but should tell you what it is
is there anything jammed inside your cig lighter?
When mine kept blowing the fuse it was because a 1p coin had managed to get stuck inside the cig lighter hole
